AV out...
gopisvara
AV out...
How excatly, and which cable do you use to watch the laptop screen on a tv on the PCG- GRT915M...thanks a lot in advance....:smileygrin: :thinking:
4 REPLIES 4
rich912
You need a 3.5mm jack to three phono (red, white and yellow) the same as an analogue camcorder cable.
Like this:
Go n-éirí an bóthar leat
GBS
Like this:
and you can get it here.
lamonine
Bonsoir,
can we have a good video quality using jack cable from pc to tv ?
Anyway i think it's my only chance to do this cause my vaio has got only input like : s-video, red/yellow/white phono, etc
I want to by a plasma TV so which plug i will have to use to connect my vaio on it ??? Maybe an external card can do this ???Or can you certify that 3.5 jack it's a good thing for this?
Thanks in advance
Ciao
lamonine
Bonsoir,
Thanks in advance
Ciao
