AW11 M/H vs AW21 M/H
akeister
I am looking at the AW series as a replacement for my current Vaio.
I am however, confused!
The AW11 is the older model going out of production to be replaced by the AW21?
The Aw 21 is £200 more expensive, BUT seems to only have a Blu ray reader and not the reader/writer as in the AW11? plus 80Gb more hard drive
This eems a more expensive laptop with poorer features? unless I ahve missed something, all other parts of the two laptops are the same?
Thalamus.
Champion
Hi Alana,
the only other difference I can see is that the Aw21M/H has the Intel® Core(TM) 2 Duo Processor P8600 (2.4 GHz) ..
If the specs are correct I can't see why I would want to spend the £200 more for the Aw21M..:smileyconfused:
