Hi all,
I am trying to find from where I can install the Backup utility that comes with WinXP Home edition that, as far as I know, is included in the original WinXP disk but not installed. The GRV616S comes with WinXP preinstalled and I do not have the WinXP disk (not included in the package).
I know I am looking for a file named "NT-Backup.msi" but I cannot find it in my system. Is it hidden under an other (compressed?) name? Considering that it is part of the system, I think I should have the right to have and install it. Am I wrong?
Your help will be much appreciated, Good Easter, Massimo
It's in the valueadd folder
Hi again, I have to sadly say that I do not have such a folder (at least not under the "valueadd" name. I searched in the whole disk including system and hidden files/folders. Am I missing something?
Thank you very much
Massimo
Hi, I now better understand the answer but my problem is that the original WinXP CD was NOT included with the Sony Vaio and I understand that the Valueadd folder is on the CD and not in the computer disk (pre-installed.
Thank you
Massimo
Thank you very much
MassimoHi,
Even in the i386 folder ?
Have you looked at your burned recovery DVDs. Do you have burned your recovery DVDs?:smileycool:
HI, I would like to thank you all for your help. After a long search I found that on the 4th recovery CD (Sony was kind enough to provide them with the machine!) there is the ValueAdd/MSFT/NTBACKUP folder that contains the NTBACKUP WIndows installer. I will give it a try. Thank you again to you all and "ciao", Massimo
No problem
Ciao
