Battery has died within 10 Months?! Guaranteed??
Mr_DoughBoy
Hi all,
Today when I've turned my laptop on it told me in Vista that no laptop battery was detected, I tried removing the power cable from the laptop and lost power immediately.
Ive removed the battery theres no sign of damage and no dirt on the contacts, is it likely to be the actual laptop or the battery??
Ive had this laptop less than 10 months and I cant believe the battery has gone already is it guaranteed for a year?
Many Thanks
Mr_DoughBoy
6 REPLIES 6
helloimgeoff1
It's got a manafacturers guarentee with Sony, although it's normally better to take it through with the supplier where you got it from, as most of the time if you have the recipt you can either get a full refund, get it repaired free, or an exchange for the same laptop again.
Best of luck, Geoff.
Mr_DoughBoy
AH thank you I wasn't sure if the batteries were guaranteed :smileygrin:
rich912
Sorry to disillusion you Mr_DoughBoy, but despite what Geoff says, Sony deem the battery to be a consumable and is therefore not covered by the 12 month guarantee.
Go n-éirí an bóthar leat
tellyaddict07
I had this problem just before christmas and my laptop was only 7 months old, i opened a case file with sony support and even though it was outside battery guarantee period they had replaced it within a week of opening the case file free of charge so you could try you might be lucky like me
jonrees69
I read somewhere that SONY's offical/unofficial warranty on batteries was around 3 months - and yes they are seen as a 'consumable' and so are not generally covered.
J
Thalamus.
Champion
Hi jonrees69
Sony has recently increased the battery warranty period from 90 days to 6 months.. :slight_smile:
