I seem to have lost the facilty to use the 'blue' function keys on my Vaio Laptop.
Cannot change brightness or swap between laptop screen and projector.
Any suggextions from anyone?
Email
You disabled anything in msconfig recently? if so enable 'VAIO Event Service' under the services tab.
You will probably have to reinstall the following Sony Utilities - and in this order: -
1. Sony Utilities
2. Sony Shared Library
3. Vaio Event Service
You don't give your model but the Original Utilities Package is usually downloadable from here: -
http://www.vaio-link.com/downloads/updates/updates.asp?site=voe_en_GB_cons
Solved with the downloads, thanks very much
