Battery Stopped Charging at 50%
Xavierbaby
Hi
My Vaio VPCEA1S1E/W battery stopped charging at 50% while cumputer still plugged in.
Please help
Xavierbaby
Hi Xavierbaby and welcome.
Check to see if you have the Battery Care Function enabled.
If you have this feature installed, to make the battery last longer - particularly if you use the Vaio plugged in most of the time - you can choose to stop charging at 50%, 80% or 100% depending on the version you have installed.
Go to Start -> VAIO Control Center -> Power Management -> Battery  (or Battery Charge Functions).
You can choose which maximum charge level you want to use.
:wink:
KatherineYH
Bad Battery Cell, Contact Sony for a replacement battery, This happens
_______________
Life is too serious to be taken seriously https://imagicon.info/cat/12-13/text-smiley.png
