Black Screen with orange flashing power button
Oceannabay
Working away merrily and screen goes black.  Power button flashes orange and I can't seem to get my work back.  It comes back eventually (after a few minutes of pressing every key under the sun) but I would like to know what is going on.  I have only had my Vaio a couple of weeks and it has already been back for repair!  Is it me?
All help and advice would be appreciated.
Thank you.
12 REPLIES 12
Thalamus.
Champion
Hi Oceannabay,
welcome to Questions and Answers..:smileyhappy:
Who did the repair and what problems did you have.?
What was repaired.?
Which of the following do you see when the screen goes blank.?
The power indicator status is as follows -
Glows green when the Vaio is on,
Blinks slowly in Orange when in standby,
Off when the vaio is hibernate or turned off.
The battery indicator status
Glows orange when battery is charging.
Blinks fast indicates battery error.
Battery & Power -
Blinks along with the green power indicator when the battery is running out of power (normal mode)
Blinks along with the orange indicator when the battery is running out of power (sleep mode)
Oceannabay
Hi Thalamus
Thanks for your prompt reply.
Sent to Sony. Had Boot up problems.   After putting in password it went back to boot up procedure, went through second time around after putting in password again. Sony have on their sheet
Boot / shutdown / power - HDD boot failure / Smart failure
What was repaired.?
Replaced 1x"GB/1x4GB memory module.  OS reinstalled. BIOS updated.  RAM 1x2048MB=61444MB total.
Glows green when the Vaio is on,                 - YES
Blinks slowly in Orange when in standby,   -  I presume my computer is going into standby mode without my help!
Off when the vaio is hibernate or turned off.  -  YES
Glows orange when battery is charging.   YES
Blinks fast indicates battery error.            Not doing this.
Thanks.
Thalamus.
Champion
can you posts the case number of your repair please.?
Just a thought - did you perhaps close the Vaio's lid for a moment?
:thinking:
Oceannabay
815585
Forgot to mention I kept getting the Bsod fault too.
Oceannabay
No, the first time I was on Skype, the second I was surfing the net.
Thalamus.
Champion
815585
Hi Oceannabay,
can you please check your have given us the correct case ID please..:smileyconfused:
If you believe the case ID is correct then I think it's best that you contact Vaio support again to try and resolve the problem, seeing as your vaio is new and just returned from repair.
To find contact details for Sony Vaio support..
Open Vaio support, either by clicking Support at the top of this page or use the following link:Vaio support
Under Log-in option 1: Enter your vaio models serial number, which you should find on the bottom of your Vaio.
Then click Log-In
Once logged select Get In Touch
Oceannabay
Hi Thalamus
Thank you very much for all your help.  I confirm that the repair number is the one given, so will take your advice and get in touch with Sony.
Regards
Thalamus.
Champion
You're welcome Oceannabay, I hope all goes well..:smileyhappy:
