zenden
blueray or hd?
can any1 tell me if my vaio ar31e laptop can play bluray or hd dvd,s?
also can any1 tell me whats thwe difference?
sorry about the probably easy question but iam a total newbie,
thanks ,
den.
6 REPLIES 6
MattWilson
Blu ray only.
BluRay are read with a blue laser instead of a red one so you can store more data on them currently up to 50GB whereas HD DVDs can only hold 25GB.
You can also play Bluray movies which are of HD quality which is much better than your average DVD.
profile.country.ru_RU.title
spider_man-unl
All is good, I think! There isn't no differences, only available space!
THX67
SORRY DVD HD HOLD 30GB AND HD DVD WORKS LIKE BD THIS A BLU LASER.
AND DVD HD TRY TO BULD A 3 LAYER DVD HD AND SO HAVE 45 GB......
MattWilson
Here is all the information your ever need to know:
BluRay
HD DVD
Thalamus.
Champion
Hi Den,
Unfortunately your AR31E does not have a blu Ray drive, so can not play blu Ray disc's.... :slight_frown:
kee-lo_
I have heard rumors you can use the XBOX 360 HD DVD drive via USB on a PC.
