Bluespace NE support for hands free headset on TR5?
veerod
Hi everybody, can anyone tell me if Bluespace NE supports bluetooth headsets for use on skype?
I can pair my device with my vaio TR5MP using either a Motorola H300 or HS810 headset, but service discovery is unknown, I've tried every configeration i know but still no connection, I have disabled the microsoft driver in the hardware profile, made no difference. I also have a vaio FE21H, that connects perfectly with the motorola HS810 and works using skype etc. but my prefered H300 headset runs through the connection wizard and accepts the passkey 0000 and pairs ok but then comes up with connection failed, everytime? any ideas on that one please.
I am desperate to get this going, i'll explain on any replies.
Many thanks
David
William
Hi Veerod and welcome,
I have read your post many times and only refrained from answering because my knowledge of Bluetooth is minimal.
Windows XP with SP2 does not include any support for headsets.
I have unsuccessfully tried to find a solution for my TR5 using various Widcomm software and stacks.
I can only assume your other laptop has different Bluetooth software and utilises a different stack.
You may find this SITE helpful in finding a solution.
veerod
Thanks for your reply William, SP2 needs to address this support, in the mean time back to the wired headset and trolling the web sites.
Nice bike by the way, mine is now a Buell XB12ss (0-100 in 3.9)
