Bluetooth Connection Problem?
alawood4
Hi! Can anyone assist please. I have successfully connected/paired my Bluetooth headset withmy Vaio and all info boxes show "connected", however the sound still only comes via the Laptop speakers. Any suggestions?
rich912
Hi alawood4,
Go to Control Panel > Sound >Playback tab. There you should see a Bluetooth device listed (assuming all the correct drivers are installed and have support for A2DP) - left click the device and select set as default.
Unfortunately you will need to repeat this procedure whenever swapping between playback devices.
Rich
Go n-éirí an bóthar leat
