bluetooth not working
Ali123456789
HI my vaio AW is having problems with the bluetooth, it says that it "could not initialize bluetoothe stack". it pairs with my phone but i can not connect to it properly and transfer files. is there an update or driver i could install that might help?
thanks :slight_smile:
Thalamus.
Champion
Hi Ali123456789,
welcome to club VAIO.. :slight_smile:
Have you tried re-installing the bluetooth driver.?
You may find the driver located in C drivers, if not then you can download the original driver from Vaio support, to open Vaio support, either by clicking Support at the top of this page or use the following link:Vaio support
Under Log-in option 2: Select your VAIO model, next to Select Model Category - Select your model from the drop down list, in your case VGN AW.
Then next to Select Model - AW...
Then click Log-In
Once logged select Downloads, then originally installed then click on bluetooth to download..
