Bluetooth on VPCEE2E1E?
xrisgarden
Hi
Do I have it already (as bought) or do I need to install it?
thanks
Your model does not appear to have a bluetooth radio fitted.  You will need to buy a bluetooth USB dongle like these: -
http://www.amazon.co.uk/s/?ie=UTF8&keywords=bluetooth+usb+adapter+dongle&tag=googhydr-21&index=elect...
Make su4re you get a Windows 7 version and look for one that is recommended with 4 or 5 stars.  There are several pages to pick from.
:wink:
:wink:
