Vaio update LAN Driver (Intel) 13.0.0.107
profile.country.uk_UA.title
varshone
I have Vaio AW4ZRF. Vaio update show an old update LAN Driver (Intel) 13.0.0.107, but it doent want to install it. How to do it? Thanks.
P.S. I install some autoupdates from intel.com. Can this be a problem?
Screens:
That Intel driver is more than a year old (October 2009).
I would guess you have installed a newer driver from Intel - so the older driver will not install.
Check what version of the LAN driver you have installed: -
Device Manager-> Network Adapters -> Intel LAN/Ethernet and check the installed driver.
:thinking:
varshone
up
:thinking:
