S-Knight
Bluetooth problems
first of all I don't know if this is the right place to put this thread but I didn't found anything else :slight_smile:
I have a problem with the bluetooth on my vaio VGN-A417M
He just doesn't want to connect to anything and I can't make it visible for my machines because then it gives a fault and says he can't adjust the settings I made. And I just checked the box that my pc should be visible for my "machine"....
anyone any advice??
thx!
TheBestofZeus
hello
i also have an A417m and i just bought a sony ericson k750i and so wanted to bluetooth eg an image to my notebook.i also checked de detection chechbox and my phone can't send the image.
what's weard, is the fact that i can use, through bleutoothconnection, my phone as remote eg windows media player, so the bluetooth works, but the notebook is not able to receive pictures through it.
any solution for this problem?
thx
