I have a VGN-A297XP, basically the system needs recovery.
I follow the instructions but a message appears "Cannot find your computer's system drive. Cannot select "C drive Recovery".
I then select complete recovery. The system starts to recover but then the following error message appears stating that "Disk access:Cannot write data on the hard disk because the sense operation failed. Recover your computer again". It doesn't matter how many times I carry out the recovery it fails and the same message appears. The disks appear to be for the VGN-A297XP but I've seen on various forums that there are problems with the recovery disks.
Any suggestions?
Thanks for the welcome and link.
I had already seen it.
I don't have another cd drive.:smileysad:
Also I don't fancy paying shed loads of money either .:smileysad:
I have posted the problem with Sony and am waiting to see their reply.
Hopefully Sony support will give you a solution
