Bought Sony Vaio but can not find CD inside?
hunker7
Bought Sony Vaio yesterday, but i was suprised when there was no CD in pack? is normal?
rich912
Hi hunker7 and welcome.
Unfortunately this is normal for most computer manufacturers these days – it is necessary for you to create your own recovery disks.
If you have not been prompted to do this then click Start > All Programmes and scroll down to Vaio Recovery Center and then select Create Recovery Disks.
Go n-éirí an bóthar leat
rich912
profile.country.ro_RO.title
fixisy
You have to create your own discs. This infos may help you:
---- URL deleted as commercial purpose - against Code of Conduct -----
Message was edited by: tweety2b
