Built-in webcam missing?
jsix22
Hi, I have a sony vaio W series, with XP. The webcam was working fine but I had a few issues with skype, so ended up uninstalling the arcsoft web companion software that came pre-installed. It must also have contained the drivers for the webcam - because the integrated webcam disappeared too.
It has literally gone. In device manager there is no option for imaging devices.
I reinstalled the camera driver from the sony website, I also reinstalled the arcsoft web companion but neither can detect a camera.
With device manager there are 2 unusual objects. The first is under non plug and play devices - just titled 'serial' with a yellow exclamation mark, and the details 'this device is not present, is not working properly, or does not have all its drivers installed. (Code 24)'.
The second is under USB Controllers and is titled 'Unknown' and states 'no drivers installed for this device' - under details it says 'USB\VID_000...' I can't update drivers with the camera driver.
I did a full system recovery to factory settings using the sony vaio recovery utility. I did it twice to be sure. The camera is still not detected, and the 2 unusual devices are still located within device manager.
Has anyone come across this before? It seems mad that uninstalling the arcsoft webcam companion can completely kill off the camera. It should come with a warning!
Any help would be really appreciated, thanks
13 REPLIES 13
rich912
Hi jsix22,
Unless anyone else has any suggestions I can only assume that there is a hardware problem that we will be unable to solve on this forum.
USB Webcams are cheap enough so I suggest that you go down that route.
Rich
Go n-éirí an bóthar leat
jsix22
OK no worries, thanks for your help
jsix22
Guess what? As if by some miracle the camera has returned.  I noticed yesterday 'scanners and cameras' had reappeared in 'my computer' so checked device manager and there it was  - a section for imaging devices with the sony webcam.  There must have been some work going on in the background to link up the unknown device and drivers .The only thing I can say is that I installed all the windows updates and the newest version of Java, and continually rebooted.
I have no idea but I'm not complaining  - thankfully I didn't opt to replace the motherboard, and as if by coincidence my new USB webcam arrived today but I am going to keep it just in case....
I would strongly advise not to uninstall the arcsoft software though, it causes a severe headache !
rich912
That’s great news jsix22 but don’t forget where you have stored that new USB webcam as you could very well have an intermittent hardware problem with the in-built camera.
Rich
