Burning CDs on VGN-SZ1M/B
filou81
Hi all. It's not possible anymore to burn CD's with my notebook. I have no clue why since I have burnt several of the same CD's before.
My VAIO: VGN-SZ1M/B
The CDs: Samsung digitall 52x, recordable multi speed
Some ideas?
4 REPLIES 4
Hi filou81 and welcome to Club Vaio.
Are there any yellow warnings or errors against your drive in Device Manager?
:thinking:
filou81
Hi. Thanks for your reply. The only warning appearing says that there is no CD in the drive.
Meanwhile I managed to burn a CD with another software. Still, I think it's strange that it's not working with the windows-own burning software - suddenly.
jumpsuit
I had a similar problem a little while ago.
Try running services.msc and then check the status of the Imapi CD-Burning COM Service.
Its status should be 'started.'
filou81
thank you!
