Camera driver for AR21SR Win7 64bit
profile.country.uk_UA.title
snippyy
Im install Windows7 64bit on the AR21SR laptop. The built-in Sony Visual Communication Camera VGP-VCC2  doesn't work. Cant find 64bit camera driver :slight_frown:
usb\vid_05ca&pid_1834
usb\vid_05ca&pid_1834&rev_0100
Need Win7 64bit camera driver.
Please, help.
warriorfullight
Since you are in Windows 7, you can check for updates where you might find the driver for your built-in webcam. Windows 7 has this feature.
snippyy
Updates (windows7 and sony update utility) checked. No results. :slight_frown:
