Can I add 512 MB RAM to my FGN-FE31H with 1GB RAM????
79manuman
Hello Vaio Freaks,
does anyone know if it is possible to add 512 MB RAM to my Vaio FGN-FE31H which is presently equipped with 1GB RAM????
Thanks in advance
manolo
Hi manolo and welcome to Club Vaio.
I think your FE31H comes with two modules of 512MB already installed. As you only have two slots, you cannot add a 512MB module - you will have to take one of the 512MB modules out and replace it with a 1024MB module.
Here are the instructions to replace your memory - best to check what is already installed.
http://support.vaio.sony.co.uk/tutorials/memory/memory.asp?m=2406&site=voe_en_GB_cons
:wink:
