Hi
The VPCEC1SE1 appears to have space for two hard drives but only one SATA connection. Is it possible to add a second drive and if so, how do I do it?
Thanks for any help.
Hi Not_At_Home,
Only one hard disk by port it's allowed.
If you want to add more disks to your system, consider adding usb hard disks or an USB hub.
Regards,
Eduardo
OK I thought as much. Thanks Eduardo.
surely you must be able to install a 2nd hdd, one of the options if you customise the 17" e-serise on the sony site is to have 2x500GB so im pretty sure you can install a 2nd drive its just a matter of finding the correct connector, i had to do something similar with a dell vostro 1700 i have which also had dual hdd bays.
