Can I connect my VGN-NR31J laptop to my television set (which has all the latest connectons).
Hi rosiejane,
The only video output from your NR-Series Vaio is the 15-pin VGA (monitor) connection.
If your TV has the same 15-pin PC Input then you just need a normal monitor cable like this: -
However, most TVs don't have this connection and you will need to purchase a VGA to TV Converter Box to get the RGB signal converted to S-Video or Composite Video signal. There is even a converter box from VGA to HDMI. Have a look at the selection here: -
With both methods you will also need a cable from the Vaio's headphone output to the TV's audio inputs to carry sound - like these: -
Thank you so much for your detailed reply. My tv does have a VGA input but it is coloured blue whereas the laptop output is coloured grey. That's what was confusing me and I wanted to make sure that I was on the right track before I parted with my hard earned cash.
Thanks agan.
