zarajan
can't remove case...
My computer makes lots of noise which I suspect is caused from the dust in the fans, but there doesnt seem a way to open the case to clean it.  Its a VPCL12M1E computer, and ive checked the user manual and couldn't find anyhting. Also does it effect the warranty or anything like that if i open the case myself?
Anyhelp woulb be appreciated. Thanks
austingrd
There could be a warranty seal that might be broken here. Have you tried calling tech support yet?
