Can you reset the login - Vaio Z600TEK ?
Fenners1980
Forgotten login - Vaio Z600TEK - Is it possible to reset / get in?
whiting1999
For Windows 7 or XP or the BIOS?
If the Windows then use Kon Boot or Trinity Rescue Kit (google) I use both and are in my IT CD/DVD folder.
If BIOS then might be a problem as not sure how easy it is to get to the BIOS battery to reset BIOS.
