Can you save your win7 OS prior to using Win 8?
635csi
I took up the offer of Windows 8 professional for $14 when I bought my Sony Viao. Now having had time to read all the comments and reviews of Win 8, it seems that the new OS is fine for tablets but a waste of time for serious work on a laptop, mainly because of the lack of a touch screen.  Even with a touch screen, most programs / aps run in full screen so you have problems copying and pasting. It would be nice to try the new os, but not unless there is a path back to Windows 7 in case I find that I cannot use it.
How do you back up your OS and hidden partition on a Viao.
Message was edited by: 635csi
Typo
Tags (3)
Thalamus.
Champion
Hi 635csi,
Your Vaio should have a hidden HDD recovery partition which should allow you to return to the pre-installed OS but to be on the safe side make sure you have created a set of recovery discs..:smileywink:
This is not model specific..
To recover from the recovery area
On models with the ASSIST button
1 Press the ASSIST button while your computer is off to launch VAIO Care Rescue.
If the display language selection window appears, select your desired language and click OK.
2 Click Start recovery wizard.
To perform the custom recovery, select Tools and click Start advanced recovery wizard.
3 Follow the on-screen instructions.
On models without the ASSIST button
1 Turn on your computer and press the F10 key several times before the VAIO logo screen disappears.
If the Edit Boot Options window is displayed, press the Enter key.
2 Select Start recovery wizard.
Thalamus.
Champion
Hi 635csi,
