Cant install graphics driver.
OlegStepanov
I want to play Anno 2070 with no lag
Message was edited by: OlegStepanov
rich912
Hi OlegStepanov,
Have you tried uninstalling the OEM driver/switching to the standard VGA graphics driver prior to installing the driver released directly by Intel? This works for AMD/ATI but not sure about Intel.
Although the following video refers to the AMD GPU it is worth a look..
http://www.youtube.com/watch?v=t2_thUnvJv4
Rich
Go n-éirí an bóthar leat
8 REPLIES 8
rich912
Hi OlegStepanov
Which Vaio model do you have and is it running the original OS?
What GPU is fitted?
Which driver version is currently installed, which driver are you trying to install and where did the driver come from?
Rich
OlegStepanov
This laptop http://www.sony.co.uk/product/vn-e-series/vpceh3n1e i donwloaded the driver from the intel site and my current driver is 8.15.10.2291 and yes it has the original os. My GPU is Intel 3000 HD
rich912
Hi OlegStepanov,
Rich
OlegStepanov
Thank you that worked but it seems like it has not improved my expirience with Anno 2070 it starts of smooth on both low and med settings but then lags after a few mins or so. Any idea why that might be happenig?
tetrapackage
If it is possible to change your current GPU, that might work as the Anno 2070 may not be compatible to your current GPU.
OlegStepanov
Well thats an obvious thing to do.
rich912
Hi OlegStepanov,
Not being a gamer it is difficult to provide advice on this.
Here are details of system requirements for the game and I suggest that you contact the developer for further clarification on whether your notebook should run the game without problems.
http://www.game-debate.com/games/index.php?g_id=1762&game=Anno+2070&p_make=Intel&gc_make=Intel&lapto...
Rich
rich912
If you had a notebook and knew anything about them you would realise that this is not possible as the graphics chip is soldered to the motherboard. Please stop posting such nonsense.
