Changing language Windows Media Center and soft?
profile.country.nl_BE.title
robbedoes37
about a month ago I bought a second hand Vaio FE21H from Italy. Now I am looking if it is possible to change the Italian version of windows and the pre-installed Sony software into the Dutch edition. I already downloaded the Drivers and Install files from the update site, and now I gotr some kind of mix. Should I find someone to supply me with home-created recovery disks, or is that not going to work either?
Thanks for your reply
Rob
6 REPLIES 6
tweety2b
Ex Commander (Was always on)
Hi Rob,
Your PC BIOS has been flashed language specific so Dutch home created Discs will not work either.
Kr,
Nico
Nico Henderijckx
(ex-Sony employee - fanboy forever)
robbedoes37
OK,
thanks for answering me. I'll just have to practice my Italian.
Rob
robbedoes37
Is this also applying to the Sony soft (stagemaster e.o.). Because these are realy hard to understand in Italian.
Rob
tweety2b
Hi Rob,
It should only apply to drivers and utilities. VAIO Software should be installable in all languages.
Kr,
Nico
Nico Henderijckx
kee-lo_
È soltanto il sistema operativo che è implicato. :wink: :tongue:
robbedoes37
And is there a place where I can download or find the Vaio software? And how can I overwrite the default installation? The utils map seems not to include the Vaio software, and the updates seem to keep the original language-settings. Any way to work around this?
Rob
