Whats the best way to go about this? Is it safe to use the 'wet and dry' screen wipes that you get?
Yes they are safe, I use the Klear wipes.
Thanks, its accumulated a bit of dust and muck from , ironicallly, trying to clean it before.
:smileygrin:
Yeah they're not easy to clean.
