How can I deal with this problem? I cant use my optical drive any more. My Notebook is a VGN-N31S/W. It is already 3 days old and I am not able to use the optical drive. I am using Vista Home Premium.
Hi Berkant1907 and welcome to the forum,
You need to make a small change in the registry.
The following involves changes to the registry and I recommend that you make a backup of your system settings before proceeding.
1.Click Start > Run and type: REGEDIT , and hit enter, or enter regedit in the search.
2. Navigate to - HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} and locate UpperFilters, (if exists) right click on this and select Delete and then OK.
3. Under the same Registry Key locate LowerFilters, (if exists) right click on this and select Delete and then OK.
4. Quit Registry Editor and re-boot the computer, new registry values will be created that will hopefully cure the problem.
After you remove the Upperfilters value and the Lowerfilters value, you may possibly need to re-install your burning software – but not necessarily.
Installing third party burning software may have caused this problem…
Hello Rich!!!
Thank you! Thank You! Thank You!
Great hint... You saved the evening... Would like to invite you for a beer;)...
You're welcome Berkant1907
Always up for a beer
