Hi Guys
I seem to have lost my Bluetooth icon in my taskbar. I have tried to enable it but, still no icon.
My phone will not detect it, so I can assume that it's not transmitting a Bluetooth signal
Regards
Atticmaster
Hi Guys
Regards
Atticmaster
Hi Guys
I have found the answer
The updated bluetooth driver from Sony has a bug, so all you have to do is reinstall the old driver, and Bobs your uncle, it will work.
Atticmaster
Hi atticmaster,
I’m pleased to hear that you have found a solution. However, did you run the manual update twice as the first run will uninstall the old drivers and the second will install the updated ones?
Hi atticmaster,
