Compatibility Vaio FE-11s and Windows Vista
modavaio
Hi guys,
I just would like to see if I can upgrade my vaio with windows vista (with an upgrade of 2gb ram) ad if the geforce 7400 go is enough and if the utilities like LAN, bluetooth and the integrated camero will work.
Thanks a lot for your help.
profile.country.pt_PT.title
V57...
Hi modavaio:
Al that you have is enough to work with Vista...but you may try to download the Windows Vista Upgrade Advisor...
Hi modavaio,
As v.57 says, your FE11S should be able to run Vista OK.
You can download a BIOS Update for Vista and all the required Vista Drivers and Utilities from here: -
http://support.vaio.sony.co.uk/downloads/updates/updates.asp?site=voe_en_GB_cons&c=0&s=VGN-FE&m=2152...
:wink:
