Help!!!!
profile.country.en_IE.title
fiomurph
Help!!!!
Help!! I got a little bit of Super Glue on my screen!!!!! How do I get it off!!!!!!!!! any help please. Thanks. :smileygrin:
Thalamus.
Champion
Hi carlowlass,
Apparently there is a Super Glue Remover available, not sure if it will damage the screen though, best check the instruction carefully before using because if the remover contains Acetone it could make the damage worse..
http://www.clp.co.uk/Product.asp?Prd=583278
97122769
Dont phone Sony. They will tell you to do a system recovery to remove the glue lol.
fiomurph
Hi 9276619
Thanks, I have already reported to Sony, and they are checking up and sticking to it! Until they find a Solution!!!! :laughing: Thanks for your help xxxxx
