connect vpcec3m1e to an rca/s-video tv
profile.country.el_GR.title
dionisis1979
Hello.
I am searching for a way to make the subject mentioned connection.
I could buy a vga to s-video/rca cable, but I have heared that it doesn't always work, so I might have to buy some kind of a signal converter instead (?)
Thank you.
Yes, you will need a VGA to Composite Video/S-Video signal converter box.
You will find several different models at Amazon from £12 to £50.
http://www.amazon.co.uk/Composite-Converter-S-Video-Adapter-delivery/dp/B004TCXING/ref=sr_1_3?s=comp...
:wink:
:wink:
