i have a 3 months old Sony Vaio VPCEB and began to heat up very bad
profile.country.ro_RO.title
tzk123
Hello,
i have a 3 months old Sony Vaio VPCEB and began to heat up very bad for 1 week.
i just reinstall the Windows and same result, after 1 hour start to heat up again.
what should i do.
it works perfectly for 3 months and began to disappoint me.
That is warm but quite honestly 73C is not seriously overheating when your processor is operating for a while at 100%.
The processor performance only starts to deteriorate when the temperature exceeds 90C so the fan is controlling the temperature OK.
I don't think there is an easy fix but if you are concerned about the fan noise, I would speak to Vaio Support to see if they have any ideas.
:smileyconfused:.
5 REPLIES 5
Please download PC Wizard and tell us exactly what temperatures the CPU, GPU & HDD reach and what software you are running when it overheats.
http://download.cnet.com/PC-Wizard-2010/3000-2094_4-10793737.html
Also where are you using the Vaio - on a hard surface or on a soft surface like a bed which will cover the ventilation ducts?
Is the fan running fast when the Vaio is hot?
:thinking:
tzk123
hi again,
thanks for the tips but i instal the program i test my tempereature and when my processor is 100% the temperature is 73C23.JPG
I install today the Windows XP Pro but same overheating.
usually the laptop stay on my desk.
and yes the fan is on when is hot and makes a strange sound like a vacuum cleaner
:smileyconfused:.
tzk123
Ok thank you for the answers,
Actually i panic because overheating since one friend of mine had the same problem with heat for 1 week and the processor was burned.
profile.country.fr_FR.title
ahzahri
I have the same probleme. the computer starts chouting and overheats ! i was obliged to open the keyboard (since the fan is under the keyboard and not under the laptop). now i can't do anything on my computer and its very sad.
Just to know that its a common problem on this version VPCEB to overheats .... i wonder if there is any real solution to the problem cause that bios upgrade aint working !
And now i have my laptop opened all the time so i can use the web browser correctly.
