Dead CD/DVD reader?
profile.country.it_SE.title
aribenig
Dead CD/DVD reader?
it has been now few days (before my battery stopped working) that the CD/DVD reader doesn't work.
It tries to read, but it doesn't seem to detect the CD that there is inside.
Is there anyway I can make a diagnostic of the failure (most likely hw)?
Would this be covered by the warranty?
Regards,
Arianna
Tags (1)
rich912
Hi Arianna,
Things go from bad to worse for you!
Is the CD/DVD drive recognised in Device Manager and reported as working? Is the drive showing in My Computer?
Have you tried both CD and DVD disks, both pre-recorded and blank?
You could try cleaning both the disks and the drive laser lens with a proprietary cleaner assuming nothing above shows an error.
Assuming that your Vaio is still within the warranty period a hardware failure would be covered. The warranty period varies depending on country of purchase - one year in certain Euopean countries two in others – I don’t know about Sweden. This also varies with operating system and whether it is a CTO model. If you are unsure you will need to contact Support.
Rich
Go n-éirí an bóthar leat
