Deleting Media Go
CanonManD550
Deleting Media Go
Hi Everyone :slight_smile:
Im new to this so please forgive me.
Basically iv organized everything on my new vaio and have uninstalled the programs witch i wont be using.
Media go is the problem  ! i have uninstalled it but it wont let me delete the folder from document and its annoying me :angry: it says it being used but i cant find the thing using it .
Can Anyone HELPPPP:smileygrin:
Tags (3)
CheesyFeet
Try checking task manager and see if any processes are running? (ie with media go as its description)
rich912
Hi StevenHallBB,
You could also try deleting the folders whilst in Safe Mode.
If that doesn't work then have a look in Services for anything that may be monitoring those folders. This would usually be connected with Vaio Media - for example VAIO Content Metadata Intelligent Analyzing Manager. Try temporarily stopping any Vaio services that are running before deleting the folders.
Rich
Go n-éirí an bóthar leat
