Dissapearing Letters
careyclose
I have a Sony Vaio all in one desktop, VGC -V2S and some of the letters are dissapearing. Does anyone know where I could get are placement keyboard or even the letters that are missing. I have considered getting another make but not sure if I will be abl to continue to use the wireless function. Any advice would be welcome.
email would be best. datru@tiscali.co.uk.
Thalamus.
Champion
Hi careyclose,
have you tired asking vaio support.?
To find contact details for Sony Vaio support click on the following link:Vaio support
Then under Log-in option 1: Enter your vaio models serial number, which you should find on the bottom of your Vaio.
Then click Log-In
Once logged select Get In Touch, followed by Out of Warranty Service.
And finally select Phone Support..
Thalamus.
Champion
Hi careyclose,
Then click Log-In
