Downgrade of a FE41S - Unable to login to the sony page. help?
sypher
Hello everyone,
im writing this because i've read that sony is now supporting downgrades of laptops to xp ....
well, i want xp (and need, for my nervous system), but i simply cant get trough the page
http://www.vaio-link.com/os/xp/downgrade/index.asp
It just tells me the infoes i give them are incorrect, and check again ...
Anyone got infoes?
As of now im fully on winxp except 2 stuff.
brightness and wifi... (both dosnt work, the wlan switcher dosnt go to 5ghz lan so dosnt work here).
thanks in advance for any infoes
6 REPLIES 6
rich912
Hi sypher,
As far as I am aware the downgrade option is only available for machine that came pre-installed with Vista Business. As your model came with Vista Home Premium this may explain why you are unable to complete the necessary login.
Go n-éirí an bóthar leat
sypher
Well then i'd like it more if they would *care* to explain that in their own pages... Thanks for your reply mate!
So now ... sigh ...
Anybody got ideas how to fix wifi / brightness? 😞
thaks in advance!
rich912
You could try the drivers/utilities from a model in the FE range that came pre-installed with XP....
As long as the hardware is identical this should work.
sypher
tried, no luck 😞
rich912
Have you installed all of the XP Utilities in order?
In particular Sony Utilities, Sony Shared Library and Vaio Event Service - followed by the other XP utilities from the FE (XP) series.
sypher
yes i did 😞
