Downgrading from Vista to XP on FZ11Z
swlabhot
Has anyone done this? I have just downgraded to XP as Vista kept blue screening on me (in fact twice in the first 3 days I had it!) and I had enough of it.
I got it running but there are still a few things I need to get working on it. I need the XP drivers for the following:
1) Motion eye cam
2) LAN (not wireless)
Two other niggles:
The 'Fn' button don't work (i.,e brightness adj).
The built-in speakers still output sound even when the headphone jack is plugged in!?
Any help would be much appreciated!
Steven.
11 REPLIES 11
MattWilson
Welcome to ClubVAIO :slight_smile:
You'd be lucky if you ever get the Fn keys working as they require a special utility and your model doesn't have any XP utilities.
As for the Motion Eye which model did you have - starts VCC?
Do you know what LAN card you have? Its likely to be an Intel card so have a look at the Intel website and see if you can find it.
What audio driver do you have installed?
:thinking:
swlabhot
Its a VGN-FZ11Z.
I read from another post on here that someone got the Fn keys to work but didnt say which utility they had installed to get it working?
I don't know which LAN card it comes with, although the wireless one is Intel Pro/Wireless 3945ABG. The LAn card is under the 'Other Devices', as Ethernet Controller so there is no way of me knowing. I had already checked Intel's site but none really sticks out.
I installed the 'SigmaTel High Def Audio CODEC'. I had to first apply the MS patch tho before it will install.
I think the LAN needs the Marvell® Yukon 88E8036 PCI-E Fast Ethernet Controller Driver - this is the XP version from the Vaio SX3 but I don't know if it will install on your model.
:wink:
swlabhot
Blencogo, I just tried the link you supplied but no joy, it says its not compatible.
Would someone with a working ethernet on the Vaio FZ11Z be kind enough to look in device manager for me and tell me what Ethernet card it is and I will go directly to the manufacturers web site to download it.
Thanks in advance!
paston
You can get it from here:
http://www.opendrivers.com/freedownload/238720/marvell-yukon-gige-driver-10.15.9.3-windows-2000-xp(x...
The setup that came with Vista should work too.
I am having an issue with using dual screen on xp, the mouse pointer looks like its exploded 😞
swlabhot
Paston, thanks a mil! At last it works!
amaru007
i'm happy to say, i've downgraded mine to xp pro.
as far as i can tell all drivers are installed. graphics, sata, lan/wifi/modem and sound. even bluetooth and the camera :smileygrin:
only problem i've encountered so far is the blueray crashing when playing movies, but i'll see what i can do about it.
still in the testing stage to see what else could be wrong.
i'll make a proper topic, much like the ar21(31?) thats there.
now onwards to the 2nd stage, to see if i can find and install the relevant vaio utilities,and to get the hdmi working :laughing:
jazzyyy
Are You have work backlight adjusting??? :thinking:
amaru007
nope its basically xp pro with none of the Fn features working (minus the mute)
same goes for the hdmi out and the S and AV buttons.
my advice, bual boot if you wanto use the full features of the laptop. i did this so i could watch bluray.
