Elements 5
co2laser
Elements 5
Hi, I have a C2S (Windows Vista) with Adobe Photoshop Elements 5 as part of the package. When I open it a message says “not compatible with operating system” and opens a link to the Adobe web site but the link for the software is not working. Anyone else having the same problem with Elements? co2laser :slight_frown:
Hi co2laser,
Have you tried the direct download from Adobe?
http://www.adobe.com/support/downloads/detail.jsp?ftpID=3569
:wink:
co2laser
Hi Blencogo,
Thanks for your reply. That's the link I'm using but the page it takes you to to start the download is not working. :thinking:
Thalamus.
Champion
Hi Blencogo,
Does this link work...
http://download.adobe.com/pub/adobe/photoshopelements/win/5.x/PSE_502_patcher.zip
