Error ehexthost.exe - Common Language Runtime with Media Center
marcd56
I have a problem with my Vaio FE21H, when I start Media Center appears this message "error ehexthost.exe Common Language Runtime. If I return my notebook at the original settings this message doesn't appear. I think that it appears if I uninstall the Norton Security, but I don't know if this is the problem. I search in Google but I don't find any solution.
Thank you and best regards.
4 REPLIES 4
marcd56
Nobody have a solution.
Pleeeease!!!
KyriakosP
same to me when i unistall norton and install Panda Internet Security the system becames very unstable and the only solution is to recover to factory settings... that is very akward...
marylu
I had the same problem. I've deleted th file
C:\Windows\ehome\ehexthost.exe.config
After that the mediacenter runs without an error
kee-lo_
