Hi
I am useless with computers so would appreciate help. When I first log on I get this message
Error loading C:\PROGRA 1\tesconet\rydial.dll
The specified module could not be found
Tesco is no longer my ISP, can you tell me how to get rid of this message please
P
Hi Peny,
Click Start > Run and type in msconfig and press Enter. A new System Configuration Utility window should open click the Startup tab.
Can you see C:\PROGRA 1\tesconet\rydial.dll listed there..?
If so click the tick to disable the program from starting, press Apply and restart your vaio..
You may get a pop-up window stating System Configuration Utility you are using the selective startup for troubleshooting your system", place a tick in don't show this window again and select OK..
Perfecto!!!!
Many thanks Thalamus
You're welcome Peny..
