Hey everyone !
My hardisk had crashed and i reinstalled nearly everything but i got a problem : I cannot find the ethernet driver
so i cannot log on internet via internet cable.
I was looking forward if you had any link to download it because i cannot find it on site.
My computer's model is : VPCEBE1M1E
Thx for your help :)
Hi opollie,
Can you please check your product model number? Is it VPCEB1M1E -if so you will find the original Ethernet driver here under pre-installed drivers and utilities:
http://www.sony.co.uk/support/en/product/VPCEB1M1E_BJ/updates
Rich
Hey ! How can i check exact number because i cannot see it on my pc : Ju/ It's just written what i've said right under the screen
Is the number wrtitten somewhere in pc ?
ps : Just have looked up for the driver wich is given in the link you gave me and when i follow instruction and i need to add the thing ( last step) It says me that therre isn't any driver that can be installed .. I just have tried the marvell one
Message was edited by: opolle
Hi opolle,
You will find the correct product model number in the BIOS, in System Information and also on the box if you still have it.
Rich
