External Keyboard for TZ11XN
jgilmore911
Does the SGP-WKB1 Bluetooth Keyboard work with the TZ11XN laptop?
Are there any other options, bluetooth or otherwise?
Hi jgilmore911 and welcome.
Porsche fan?
The TZ11XN should work with a bluetooth keyboard as it has bluetooth installed.
However, I find bluetooth a bit unreliable.  A 2.4GHz Wireless connection is much more reliable and avoids the pairing issue.
Any third party keyboard that comes with a tiny Nano USB connection should be fine.  I have a Logitech K400 which has an incorporated trackpad and mouse buttons.
http://www.amazon.co.uk/Logitech-K400-Wireless-Touch-Keyboard/dp/B005LDLQXG/ref=sr_1_1?ie=UTF8&qid=1...
:wink:
Porsche fan?
:wink:
