LucasKarp
Extreme heat
Hello
It seems that I have a problem of extreme heat with my Vaio VPCS13C5E.
I just performed a full re-installation of the system, so computer is clean and still.
i did Google and red forum, but there is no solution to that anywhere.
non of the fansinks are covered, laptop is sitting on my desk
below a read out from SpeedFan just after turning laptop on (attached as well)
and after a moment which took me writing this post
Any idea how to solve it?
Is it even safe to have this computer on?
Message was edited by: LucasKarp
13 REPLIES 13
LucasKarp
Hello
Did you have a chance to check on it?
Many Thanks
Lucas
Hi Lucas.
Vaio Support said they would speak to you to explain that on older CTO Models (before 2011), some models have a 12 month warranty and some 24 months.
Vaio Support say your warranty expired in December 2011.
Do you have the original Warranty documents?
:thinking:
LucasKarp
Hi
yes I do have all the paperwork. Does it change anythng?
Sad to hear that one of most expensive models doesn't have 24 months warranty
Only if it specifies the terms of the warranty.
Sadly, 12 months is the standard warranty in the UK.
:thinking:
