hi
for some reason i seem to have an f:/setup.exe in my start up items i guessing it is my dvd rw drive as that has the letter f
i need to know if this is normal or can i remove it from the start up
regards ben
Yes you can remove it from the startup - it looks as though a bit of an install routine has been accidentally left there.
yeah i did move it from one ata to the other as well was going to strip my drives until i found out you can only do that with xp pro
i will remove it now
thanks
regards ben
