Hi All, I have just got me a brand fire new fe41z and it wont connect to my bt home hub via wireless, It cant find the hub and i tried eveything you can think of to solve the problem but obviously i'm not good enough!! Everything is working so i think i have to change a setting somewhere to make it find the hub. Any ideas, please help?! Mark
Is this problem with Windows Vista or XP?
its with vista but hey presto its started working now! and i dont know what i did. BUT now my motion eye wont work, i think its the 2.1 motion eye. It says that another program is using it but nothing is running. Any ideas?? please help!
Hi Brova Dodds
Welcome to Club Vaio.
You are not alone with this problem, there several posts on the forum regarding the Motion Eye camera problem, this has been reported to Sony and we are waiting for an update..
Have a look at the possible solution posted in this thread ..
Hi, thanks for that, its worked :smileygrin: :smileygrin:
You're welcome...
