Firewire/i.link port for VPCEE2SIE
robvaio2011
Hello
I was wondering if anyone can help me please
I purchased a Vaio VPCEE2S1E about a year ago, and im trying to get video onto it from a fairly old mini dv camera.  HOwever, im under the impression i need an i.link port to import the video.
Im aware that the vaio model im using doesnt have a firewire/i.link port - however, doe anyone know whether its possible to add one to this model?
Thanks a lot!
rich912
Hi robvaio2011,
On checking the specs for your model it doesn't have an Express card slot, but it does have 4 USB ports...
Rich
Go n-éirí an bóthar leat
4 REPLIES 4
rich912
You can add Firewie/iLink connectivity via either USB or Express card slot.
Google USB to Firewire/iLink or Express card to Firewire/iLink.
Rich
robvaio2011
Thanks for your response!
So, there is a spare expresscard slot in this model?? ( i dont know what im looking for!!)  i know from the spec there is no PC Card slot....
Thanks again
Message was edited by: robvaio2011
rich912
Hi robvaio2011,
Rich
robvaio2011
THanks a lot Rich912 :slight_smile:
