I have a brand new notebook from sony, its product name is SONY-SVE1712S1RW, and its model number is SVE171E11V.
AFTER DOWN GRADE win8 to win 7..
The function keys is working on it, such as the volume control buttons. But FN+f1 (turn off tuch pad) is'nt work.
Sony havent been very helpful with this, and its a brand new computer, Any ideas on what to do?
Regards
Massimka.
ДЕнь добрый.
После переустановки с WIN8 на WIN7
У меня новый новый ноут SONY-SVE1712S1RW, номер модели SVE171E11V. На нём работают практически все кнопки FN, но кнопка выкл тач пада не работает.
Есть ли какоето решение? МОжет драйвер клавиатуры?
ЗА ранее благодарен.
Массимка.
Hi massimka and welcome.
Have you tried installing the drivers from a previous model that was released with Windows 7? You will have to find one with a similar specification.
You will probabl need to install :
Touchpad Driver
Sony Shared Library
Hotkey Utilities
But probably many more!
http://www.sony.co.uk/support/en/product/SVE1711S9RB/updates
Yep, I've just downloaded hotkey_SOAOTH-62700000-0042 from link that you provided.
It wrote this update is not intended for use with your...
It's does not work.(
