my Fn keys do NOT work anymore, nor does the S1 and S2 key
(audio volume, brightness, external monitor etc.)
Please help on how I can fix this problem - updated new BIOS etc - which Utility (I have 9) do I need to re-install to fix this problem.
Thank you.
Hi, you have to install the utilities from the vaio-page. Thats all!
Or in C:\Utils\
i installed the utilities again - however these are not in sync with the bios update - where can i find new updated utilities which will work with the new bios? Can't roll back the bios.
u ave to install the utilities which include your hotkeys. If it doesnt work still , try reinstalling windowsXP and then install the utilities.
